63 Idler Pulley - NCRS Discussion Boards
63 Idler Pulley
  • Peter Ansted
    63 Idler Pulley
    My 327/340 does not have an idler pulley. Should this engine have one and if so,
    how is the belt routed ?
    • 43234
    Re: 63 Idler Pulley
    Peter-----
    Use, I believe that it should have an idler pulley. Originally, this idler pulley assembly was of GM #3829191. I don't recall, at the moment, the belt routing, though.
    • Dennis F. King
      Re: 63 Idler Pulley
      Peter
      Your engine should have a double pulley at the water pump and at the crank. The idler belt runs on the inner most grove around the water pump and the crank, looping around the idler pulley at the same time. Tension is adjusted by the idler pulley. Hope this helps! Dennis
