72 Wiper Door Vacuum - NCRS Discussion Boards
  • John L.
    Infrequent User
    • April 1, 1999
    • 14
    When I turn on the wipers the door opens immediately. When I use the manual valve it opens in about 4 seconds. It has always operated this way. I have had the car 3.5 years.
    The OPs judges tell me the door should open immediately using the manual valve. If this is correct, what should I look for in the system to correct this problem? I hope to PV the car soon so I need to get this corrected.
    Re: 72 Wiper Door Vacuum
    Check the integrity of the under steering column over-ride switch as well as the vac line routing. The two (wiper switch and over-ride switch) are related (both feed from common vac source) but there are individual switches for the two functions as well as vac out routing paths.
