dressing a black car - NCRS Discussion Boards
  • Henry361301
    I'd like to hear any advice from owners of black cars in regards to waxing/polishing, such as products used and tips on getting a perfect, no swirl look. Henry
  • Bill C.
    • December 1, 1991
    • 177
    Re: dressing a black car
    Henry......
    Are we talking about base coat/clear coat paint, enamal or lacquer??? These products all differ in composition and require different care.
    • Henry361301
      The car has base/clear coat, I'm sure
      • Bill C.
        • December 1, 1991
        • 177
        Henry.......
        Go to "zanobros.com" and look at the products for that application bc/cc. The products there seem to be the best using the product specified for the application intended. If you plan to use a buffer then use ONLY an orbital type to prevent burning the paint. These products can all be applied and removed by hand and a buffer will only speed up the application and removal. Use all the products recommended and you will be very pleased with the results. I have used and recommended these products to many others and the the results are always the same..........TERRIFIC. Good Luck, Bill
          We power-buff every square inch of new Vipers with 3M "Finesse-It" before they're shipped; extremely effective in removing "swirl-marks" on dark-colored cars. The Zaino website is www.zainobros.com.
