C1 - Dash pad Glue - NCRS Discussion Boards
C1 - Dash pad Glue
+ More Options
Posts
  • Jim K.
    • August 31, 2000
    • 554
    C1 - Dash pad Glue
    Any advice on the glue I can buy "over the counter" such as a 3M spray product or a brush on contact adhesive from my local home center. Thanks!!!
  • Ed Jennings
    Re: C1 - Dash pad Glue
    The 3M spray stuff is hard to beat. IMHO, very little adhesive is actually required to install a dash pad.
    • Ray C.
      • June 30, 2001
      • 1132
      I used 3-M glue when I installed my dash pad. The pad was fine for the fist couple of weeks, and then from the interior summer heat the pad came loose from under the windsheld passenger side. The cause could have been poor instlation procedure on my part or a lack glue coverage. I check with the Al Knoch Co, the manufacture of the pad on the correct type of glue to use and they recomended a glue with more open time. I would check with the manufacture of your pad for recommendations on the type of glue.
      Ray Carney
      1961 Sateen Silver 270-HP
      1961 Fawn Beige 315-HP
      • Jim K.
        • August 31, 2000
        • 554
        Thanks Ed, but what is the exact product, 3M____?
        • Jim K.
          • August 31, 2000
          • 554
          Re: Thanks Ray!! *NM*
          • Ed Jennings
            3M General Trim Adhesive #08080
            • Loren L.
              • April 30, 1976
              • 4104
              If you wantto be able to move the pad a little bit while installing, "yellow
              death"- 3M weatherstrip cement - will work. Some of the spray stuff works entirely too quickly, plus there is apparently some question as to whether the trapped aerosols contribute to separation.
              • Jim K.
                • August 31, 2000
                • 554
                Thank you Loren and again Ed!!! Jim *NM*
                • Dave Christensen
                  I had trouble with this "bleeding through" white/light material and turning it yellow after it was in the sun for awhile.
                  Does anyone have any recommendations on how to prevent this or another material?
                  thanks
                  Dave Christensen
                  • Joe Fisher
                    Pad t*******
                    What I did to prevent the pad from shrinking and comming out from under the weather strip, was not to trim the pad even with the top of the dash. I allowed the vinyl to extend past the dash, and rolled it down into the window channel. I timmed the foam from the vinyl that extends past the dash top. Then with a heat gun, slowly heated it to conform to the 'L' channel. Then I trimmed it off. This way, I have about and inch or so of excess vinyl to shrink before it comes out of the weather strip.
                    • don whitehead
                      I did not use any glue on mine. The trick is to trim it very carefully. We must have spent 8 hrs t******* and fitting. Speaker grill, defrost outlet, corners etc. I also put it under the windshield frame. Make sure to trim it enough so it lies flat in the corners. Good luck. Its a pain IMHO. But a labor of love?
                      • Jim K.
                        • August 31, 2000
                        • 554
                        No glue! wow, I may have to consider that. I can understand how most everything on top, front and sides can hold it in place, but what about the bottom? Also how long has it been in the car so far? Any regrets?
                        Thanks Don!!!
                        Jim
                        • don whitehead
                          Over a year. Been out in the sun too, at shows, etc. The only thing I should have done is trimmed and flattened it more with a heat gun under the windsheild corners. The creases on the Al Knoch pad are sharp. The crease shows if you pull up the weatherstrip, but is ok otherwise. Had I trimmed more, it would have laid down more. The panels and moulding combined with the dash and glove tray seem to do just fine holding the stuff in place. The front is under the windshield.
