Cross check: A/C to Chapanion - NCRS Discussion Boards
+ More Options
Posts
  • Larry Low
    Need equivalent Chapanion part number that equals A/C R44TS and R45TS.
    Thanks, Larry
  • Tom Merkel
    Re: Cross check: A/C to Chapanion
    Larry - Just curious - what engine are you using for the A/C to Champion cross-check?
    Thanks.
    Tom
    • Larry Low
      It is basically a stock 454 out of a 86' Surburban. It burns quart of oil every 800 miles which blackens the plugs. Not bad enough it causes misfire, but not a clean burn. It needs to be rebuilt. Currently using R44TS. Was looking just to trial and error different type plugs. I wounded it by switching from 30W to 10W30 one weekend. Two weeks later it ground down #8 cam lobe and about an 1/8" off the lifter. Go figure! Not having the time to rebuild I just swapped cam and lifters and went back to 30W. That was last summer. Makes for a great story, but was a real heart breaker.
      Take care,
      Larry
