Oill Fill Tube - NCRS Discussion Boards
Oill Fill Tube
  • chad frost
    Oill Fill Tube
    How do you replace a broken oil fill tube on a 1963? The break in about half way up the tube.
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Oill Fill Tube
    Chad, the tube is a press fit. Better to remove manifold and fit a plug (slight clearance fit inside tube)and tap out using a hammer. New one is also press fit, set in careful use of a block of wood and hammer.
    • Tom C.
      • February 1, 1978
      • 45
      Re: Oill Fill Tube
      Chad,
      Manifold removal is not necessary. Old tube will pull out with a little wiggling back and forth. Position the new tube correctly for air cleaner hose and tap in as recommended with wood. Simple 5 minute job.
      Tom Christmann
      Member #1789
      • Gary Fickeisen
        Re: Oill Fill Tube
        You may want to stuff a clean cloth down the tube to catch wood chips. Just don't forget to remove it.
        Gary
