Anyone tell me who sells the "end cap" for the power steering contol valve. I would prefer one with an X as original but any type cap will do. Thank You in advance.
C2 power steering control valve
Re: C2 power steering control valve
Joe,
I was just about to have mine rebuilt by a local shop, when I looked in the box of parts I got from the seller of the car , and I found a newly rebuilt valve by "A1 Cardone" So close to the original that I consider it a done deal !
It does not have the X in the cap but it is all there !
My long way around point is this, either your local rebuilder shops may have some lying around or it would seem that Cardone should have them .
It is probably worth a phone call. Their tech support line # is 888-280-8324
Jim- Top
I'll be interested in responses to your question.
The last I heard years ago was the "C" marked end cap was available. Since the end caps were mechanically identical, the "X" marked Corvette end cap, however, was not to be found. The "X" must have been a marker or broadcast code to identify Corvette specific valves. Once the vehicle assembly was complete, the actual mark, like other broadcast codes, was irrelevant...yeah, right, except for judging.- Top
