Terminal junction blocks '53 -'57 - NCRS Discussion Boards
  • Michael L.
    • July 31, 2005
    • 562
    How may circuits on the terminal junction blocks found in the engine compartment? I'm looking at one wiring diagram showing 6 and one that shows 5. If it is 5 connections, they must share the same ground, correct? Headlights and signals run through these.
    Mike
  • Robert S.
    • July 31, 2004
    • 377
    Re: Terminal junction blocks '53 -'57
    My 54 had 4 double terminal strips on the driver side and 5 on the pass side.
    Bob
    • Robert S.
      • July 31, 2004
      • 377
      Opps...5 on both sides.
      Bob
      • Roy B.
        • February 1, 1975
        • 7044
        53-54 is different then 55 *NM*
        • Michael L.
          • July 31, 2005
          • 562
          Re: 53-54 is different then 55
          Roy, ir there 6 on your '55?
          Mike
          • Roy B.
            • February 1, 1975
            • 7044
            About the same as the 55 Car but dont use all the connections
