63 #'s - More questions - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    The Tonawanda "180" block has the following stamped on the pad on the right front of the block : TIOOIEEH . Joe C. previously replied with the code sequence, but there are too many characters to fit the sequence. Can someone decipher this ?
    Also, the intake manifold is 3844461 GM . It is apparently aluminum, since a magnet doesn't stick to it. Origin ?
  • Wayne C.
    • November 1, 1978
    • 289
    Re: 63 #'s - More questions
    Can't help with the engine stamp, "EEH" suffix doesn't appear in any of my references.
    Manifold 3844461 was used on 365hp Corvette engine in 1964 & 65 and on 350hp engines in 65... it was an evolution from 3794129 (340hp 1963) and 3795397 (340hp 1962).
