66- Emergency brake bracket removal ?? - NCRS Discussion Boards
  • Keith B.
    • August 12, 2007
    • 220
    Now that my cluster is out, etc I want to take my e-brake L - black bracket off to repaint it. It's the black bracket that houses the e-brake handle/rod to the firewall.
    I disconnected the brn wire to the switch, started to turn the e-brake handle counterclock wise as it is threaded into the firewall housing but stopped when I realized I probably need to loosen the cables?????
    What is the correct procedure please to remove please.
    Keith
    #47685
