'62 Heat Shield Screws - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    The AIM shows the heat shields on a '62 are fastened to the engine block with a part number 193938 screw assembly. It's a 1/4" screw with a captive washer. I believe it's called an "assembly" because the part contains that washer.
    I'm trying to determine if this washer is flat, split, or toothed.
