part # question .GM #3927190 t'stat choke coil - NCRS Discussion Boards
  • geno
    can anyone tell me if this is correct for a 74 base engine 350 automatic?
    • 43232
    Re: part # question .GM #3927190 t'stat choke coil
    geno-----
    No, it's NOT the correct one for your application. The GM #3927190 choke thermostat is designed for use with intake manifolds which have a cast-in choke stove. Specifically, these included most 66-70 applications and the GM #3927190 is applicable to 68-69 with Rochester Q-Jet carbs.
    1971+ applications (and a few 1970 non-Corvette applications) used choke thermostats with an INTEGRAL choke stove. Your 74 application requires GM #326079 which is still available from GM for a current list price of $14.22.
