CS113R camshaft - NCRS Discussion Boards
CS113R camshaft
  • Joe M.
    • February 1, 2005
    • 590
    CS113R camshaft
    Where in the state of NJ can this Speed Pro camshaft CS113R be ordered?
    This is the mechanical cam for the HP engines thru 1963.
    I founf Parts America carries Speed Pro Cams but their response is, "Unfortunately, at this time the part(s) you requested is not available to us". They even show a CS1103R hydraulic cam but can't get the CS113R??
    I am waiting for a clarification but hold out no hope. The Napa, Autozone and couple of independants don't carry the brand and won't order it.
    Feel uncomfortable getting one on ebay especially when you calculate the shipping from some of these sellers. NJ has everything imaginable, where do they keep their CS113R cams?
    Chasing the wild goose,
    Joe
  • Joe C.
    • August 31, 1999
    • 4598
    Re: CS113R camshaft
    Joe,
    That should be the old Duntov "097".
    Did a quick search, and found this:
    http://www.amazon.com/dp/B000CPAUNA?...0&linkCode=asn
    Let me know.
    Did you try LICS? Dr. Rebuild? Zip? Any of the Corvette parts houses?
    Joe
    • Joe C.
      • August 31, 1999
      • 4598
      Re: CS113R camshaft
      Joe,
      Let me know.
      Joe
      • John D.
        • December 1, 1979
        • 5507
        Re: CS113R camshaft
        Joe, Try the local CarQuest store. I assume you have those in NJ? I know my local NAPA store could not order it. Order the matching solid lifters AT992.
        My 63 FI car is running that cam. At 900 RPM it has about 16" of vacuum.
        If you have problems email me at johndegreg@aol.com
        For some reason my email address here is marked private. I have to figure out how to undo that although I get too many emails now. John D.
        • nancy charles
          Re: CS113R camshaft
          got mine at my local speed shop for my 327/340hp runs great at 900 rpm with great vacum....... used VC 1810 vacum can from NAPA ...... NANCY
          • John N.
            • February 1, 1975
            • 451
            Re: CS113R camshaft
            Consider Summit.If you have the part # they will get it for you at a good price.
            Regards
              • 15673
              Re: CS113R camshaft
              NAPA doesn't carry any Federal Mogul brands because NAPA is owned by Dana Corp.
              Use the NAPA cross reference to run the F-M or GM number. Likely they sell an exact replacement under the Clevite brand or other Dana brand.
              In fact, it's quite possible that Dana actually buys he cam from F-M or vice versa.
              • Dick W.
                • 10483
                Re: CS113R camshaft
                Carquest stocks FM parts
                Dick Whittington
                • Jack W.
                  • August 31, 2000
                  • 358
                  Re: CS113R camshaft
                  1. someone is selling one NIB on the CF right now (not me, I know nothing about the seller): http://forums.corvetteforum.com/show....php?t=1910823
                  2. I think Scoggin Dickey might have it.
                    • 43221
                    Re: CS113R camshaft
                    Joe----
                    Most of the Corvette parts suppliers don't carry internal engine parts. I highly recommend Amazon.com or Summit as suggested by others. Amazon is a great source and they apparently have this cam in stock. I have found that they offer VERY prompt shipping and will even do next day air for additional charge.
                    Summit also offers VERY fast shipping on in-stock items. However, I sort of doubt that they'll have this cam in stock. Nevertheless, they are an excellent source.
                    • Loren L.
                      • April 30, 1976
                      • 4104
                      Performance Chevy here in Phoenix has
                      access to a clone - I have one in my '60 racer and idle and the bark are good to go. 602-254-9586 and ask for Bill Knobloch. He's run ads in the Driveline and I believe the price is under $100.
                      • John D.
                        • December 1, 1979
                        • 5507
                        Re: CS113R camshaft
                        Dick, I have no problems ordering that cam from Car Quest. Last one I ordered took about three days to get. I only go to Car Quest and NAPA. Car Quest is growing soo much. All over the USA now. John
                        • Joe M.
                          • February 1, 2005
                          • 590
                          Re: Performance Chevy here in Phoenix has
                          THANKS GUYS!
                          Found a carquest about 20 miles away that will order the cam. Sometimes it just gets so frustrating trying to get parts you think are readily available. Ever try to get male female brake line parts when making up your own lines?
                          Thanks again,
                          Joe
                          • John D.
                            • December 1, 1979
                            • 5507
                            Joe, My local NAPA store stocks a ton of brass fittings. So you are making up your own brake lines. Be careful my friend. That is a hard project double flaring those steel lines. The flaring kits you buy sure don't last very long. I can remember when I was a kit making the double flared line on my old hot rod. Well one day the pedal went to the floor. That was a panic time for sure. The flare let loose and it was good by Charley. John
                            • Dick W.
                              • 10483
                              FIPhart, I did not know that you had to flare a camshaft to make it work
                              Dick Whittington
