69 Vette bonding material - NCRS Discussion Boards
  • Rick M.
    • May 3, 2007
    • 76
    Can any one advise. The bonding material that bonds the wheelwell to the fender has seperated slightly. Just enough so if you push down on the top of the fender they seperate. I want to pry open the seam with a tongue depresser and inject an adhesive. Any recommendations on what type of adhesive?
    Rick
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 69 Vette bonding material
    Original adhesive used was polyester bonding adhesive. I would use this, althiugh the more modern 2 part epoxies may be easier to "inject" because they employ a mixer/applicator resembling a caulking gun.
    oe
    • Joe C.
      • August 31, 1999
      • 4598
      oe
      • Rick M.
        • May 3, 2007
        • 76
        Thanks Joe
        That's what I was thinking. I'm a boater and use epoxy a lot. My concern is the heat it generates. The marine stuff we use melts a plastic cup in about three minutes and don't want to put that on my car. Do you have experience with a particular brand?
        • Rick M.
          • May 3, 2007
          • 76
          Thanks Joe
          • Dick W.
            • 10483
            Lord Fusor makes an excellent panel adhesive
            Dick Whittington
            • Dick W.
              • 10483
              Dick Whittington
              • Rick M.
                • May 3, 2007
                • 76
                Thanks Dick,
                Is it thin enough I can inject it with a syringe?
                • Rick M.
                  • May 3, 2007
                  • 76
                  Thanks Dick,
                  • Dick W.
                    • 10483
                    It will have to be a large bore syringe. I believe that a 50 or 100 cc syringe will have a nipple large enough. BTW be sure to rough up both surfaces prior to bonding.
                    Dick Whittington
                    • Dick W.
                      • 10483
                      Dick Whittington
                      • Wayne W.
                        • April 30, 1982
                        • 3605
                        Any epoxy that generates that much heat has some serious accelerators in it. There are many formulations of epoxy. Most are not nearly that aggressive.
                        • Wayne W.
                          • April 30, 1982
                          • 3605
                            • 43219
                            Rick-----
                            Are you sure that the plastic cup actually melts from heat or could it be simply a case of the organic compounds in the epoxy chemically reacting with and "melting" the plastic? If you are talking about a styrofoam cup, I would expect the epoxy to react with it.
                              • 43219
                              Rick-----
