I am preparing my 65 Coupe for a PV. The PV Guide is very clear about tires..."The Corvette must be equipped with original type bias-ply tires". The Guide does not mention the tire balance wheel weights. For Flight Judging, weights must be on the inside of the wheel to avoid a deduction. Would weights installed on the inside and outside of the wheel (for more accurate balancing) warrant a PV failure?
DP
DP
