69 427 dip stick tube seal - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    What is the proper seal to seal the dip stick tube to the oil pan tube for the 69 big blocks?
    The AIM shows it as a rubber tube...is that correct? If so are these available any where and if not what are you guy using to replicate this seal?
    Greg Linton
    #45455
    • 43221
    Re: 69 427 dip stick tube seal
    Greg-----
    It's not a tube, at all. It's an o-ring-like seal of GM #274244 and it's still available from GM under the original part number. About 5 bucks, GM list.
      • 43221
      Greg-----
      • Greg L.
        • March 1, 2006
        • 2291
        Yes Joe you are correct.
        I had a longer and closer look at my AIM and I see that the seal that you reference is an O-ring on the dipstick tube itself. What I mistook for a rubber tube type seal was actually the metal tube on the oil pan that receives the dipstick tube.
        Thanks for clearing that up.
