69 L36 fuel hoses - NCRS Discussion Boards
69 L36 fuel hoses
  • Greg L.
    • March 1, 2006
    • 2291
    69 L36 fuel hoses
    Are the supply and return fuel hoses between the frame and fuel pump both molded "S" shaped hoses or are they just regular fuel hoses?
    Greg Linton
    #45455
  • Michael M.
    • February 15, 2007
    • 455
    Re: 69 L36 fuel hoses
    Not sure, I just replaced my tank in my '68 L36 and the hoses. I got new hoses from Doc Rebuild and they were not molded. So if Doc Rebuild is an accurate point of reference, the hoses were not molded.
    • Dick W.
      • 10483
      They were molded. Used to be able to buy the molded hoses from the good Dr. but apparently his source has dried up
      Dick Whittington
      • Greg L.
        • March 1, 2006
        • 2291
        Thanks Dick.
        Micheal, are you refering to the rear hoses at the tank or the front ones at the fuel pump? I was questioning the front ones but it sounds like you were refering to the rears...just wanting to clarify.
        • Michael M.
          • February 15, 2007
          • 455
          I was referring to the ones at the rear connecting to the fuel tank. Sorry for the confusion. I didn't read carefully enough. I saw "fuel pump" in your post and was thinking "fuel sender".
