Clues - 64 Delivered With Factory KO's ?? - NCRS Discussion Boards
  • Jace H.
    • April 1, 1997
    • 253
    What are the clues that a 64 originally came with factory KH Knock Off's. I know that the jacking instructions showed a KO wheel. Any differences in the spare tire carrier bolt length etc..?? What else is there?
    Jace
    #28944
  • Alan Drake
    Re: Clues - 64 Delivered With Factory KO's ??
    The two long bolts towards front of car which hold the cover are also different. These look like the 3833383 with a welded nut as opposed to the 3841463 which has the flared area instead of nut. If you car did not have KO's then the 3841463 would be there now. That's my understanding at present from NCRS documents, however just can not find them today so if an expert responds to your post go with that comment first.
