C3: Date code on 1973 L82 cylinder head - NCRS Discussion Boards
  • Christopher K.
    • September 10, 2007
    • 311
    I can't figure out what that first letter is on my 1973 L82 cylinder head.
    Car has an H15 build date and block is C 7 3, so I believe that letter should be an A or B.
    Can anyone help? Please see pic link
    Thanks in advance
    Chris
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
    Looks like 330545 to me.... *NM*
    • Christopher K.
      • 311
      Re: C3: Date code on 1973 L82 cylinder head
      Thanks Jack, your right.
      I just need to read the first letter of the date code
      Chris
        Ah, the date code emboss! Well, it IS fuzzy and indistinct, but that's not uncommon for cast letters/numbers. More light would help as well as shots from slightly different angles with the valve cover removed.
        Might be a fuzzy 'G' or 'C' from what I can see in this 'through the hole' pix...
