Roy, you up? - NCRS Discussion Boards
Roy, you up?
  • Joe R.
    • July 31, 1994
    • 287
    Roy, you up?
    Roy, how can you tell if a 54 heat riser is open or closed? I am having a stalling issue when the engine gets to normal operating temp and I suspect the riser. Maybe my spring is on backwards??
    Joe
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Roy, you up?
    The heat riser weight is in the up vertical position when cold and down horizontal position when hot .
