Help with Part Numbers - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    I have the following fan belts and would like to know what their applications are.
    GM Pt# 9433761
    GM PT# 9433768
    • 43242
    Re: Help with Part Numbers
    George------
    For a part like fan belts, the application range is HUGE. The particular belts you mentioned are both "cut" style belts and were generally used for 1973 and later applications. They are SERVICE-only for earlier applications.
    The GM #9433761 was the alternator drive belt used for 1973-74 Corvettes with 454 and without power steering. It has a fair number of SERVICE-only applications for earlier Corvettes. It is a 7/16" X 54-1/2" belt, coded "GT".
    The GM #9433768 has no Corvette applications that I can find, either PRODUCTION or SERVICE, although there may a few. It is 7/16" X 58" belt coded "HA"
