Headlight Washers - NCRS Discussion Boards
Headlight Washers
  • Jerry G.
    • February 1, 1989
    • 227
    Headlight Washers
    I just purchased a 71 LT-1 today from the second owner that they've owned since 79, and I noticed that it has headlight washers. I can't find any option code for a 71. It's a very early car that was built the first month of production. Could it be a carry over from 70? Just curious.
    • 43260
    Re: Headlight Washers
    Jerry-----
    The headlight washers were never an option. They were standard equipment for the 1969-E71 period. Early 1971's do have the headlight washers (through about early December, 1970 build). The car should also have a 5 port washer pump.
    • Mike E.
      • February 28, 1975
      • 5141
      The judging manual spells out that and much more--sounds like a great car!!! The manual will help you decipher what's correct and what's not.
        • 3416
        My 71, #6589, mid-January build, has the 5-port pump, cut off washer hoses as part of the vacuum hose 'bundle', a short (3 inch) piece of hose running between 2 of the ports on the pump, and no nozzles on the headlight bezels, but 2 holes on the vertical center of the bezel. This all coincides with the 70-72 Tech Manual. So much accurate information in such a small book!!!
        • Mike E.
          • February 28, 1975
          • 5141
          #2584--the one I just wrote about in the Restorer, was configured exactly as yours is.
