TI ignition - NCRS Discussion Boards
TI ignition
  • robert leazenby
    TI ignition
    Tomorrow I am doing a compression test on a 70 LT-1 equipped with the transistorized ignition. Plugs are out and I want to disconnect the coil wite for obvious reasons. Does anyone know of any concerns regarding the TI ignition. I don't want to overoad anything or damage the amplification unit. Are there any other wires that I need to disconnect.
    Side note: Any ideas what compression should be with 11.0 CR
    • 15674
    Re: TI ignition
    Suggest you disconnect the amplifier plug. This will eliminate the 12 volt power to the amp. The magnetic pickup in the dist. will still induce a voltage (that will not get to the amp.), but I don't think it will hurt the pole piece to generate a voltage against an open circuit.
    The compression pressure should be in your service manual. In 1963 base and L-75 are speced at 160 psi; 150 psi for SHP and FI. Eventhough the latter have higher static compression ratio, the valve timing of the Duntov cam kills some low speed dynamic compression.
    duke
