'66 327 engine removal clearance question - NCRS Discussion Boards
  • Jeff S.
    • July 31, 1984
    • 384
    Is it necessary to remove the p/b booster & master cylinder in preparation for engine removal? Trans (p/glide) will remain in the car. It looks kind of close; perhaps it will clear straight up without the LH exhaust manifold.
  • Bill S.
    • August 31, 1999
    • 104
    Re: '66 327 engine removal clearance question
    We pulled it on this 67:
    however there does appear to be pleanty of room available if left on
    We also left the trans in the car
    Bill
    • Anthony S.
      • April 3, 2008
      • 183
      Jeff,
      I was able to take the engine (327) out of my '68 with just the radiator, shroud, water pump & exhaust manifolds off.
      I had to lift the engine up a little to get the exhaust manifolds off due to bolt clearance.
      I left the P/B booster & master in the car.
      I ended up taking them out & having them rebuilt along with the rest of the engine bay & front suspension "while I was there."
      Good luck,
      Anthony
