ignition switch - NCRS Discussion Boards
ignition switch
  • Michael B.
    • March 31, 2008
    • 88
    ignition switch
    hello, has anyone ran into this problem,I bought new switch and put in new lockset it works when you turn it on,works in the start and off position,but when I turn to lock position the lockset comes back out of switch, I think remember there was a small button in switch to prevent this but my new switch hasn't got one is this the problem thanks,mike
  • Peter L.
    • May 31, 1983
    • 1930
    Re: ignition switch
    Mike - There's a problem somewhere. What year switch are you working with? If you are working with a 68 or earlier switch, there should be a spring loaded brass pin in the switch at the front at the edge of the lock cylinder bore. New switch should be the same configuration as the old one. Pete
    • Michael B.
      • March 31, 2008
      • 88
      Re: ignition switch
      peter,I'm working on 1960.I looked at switch dosen't have brass button but looks like a hole were one should be.I know other ignitions I worked on long time ago had what you are talking about. but they didn't have lock position I will can supplier monday, the problems always seem to happen on weekends thanks mike
      • Peter L.
        • May 31, 1983
        • 1930
        Re: ignition switch
        Mike - The spring-loaded "release" pin in the switch prevents the lock cylinder from going past the furthest designated counterclockwise position.
        All the Delco-Remy in dash ignition switches I'm familiar with used in the mid-50s to 1968 on Corvettes and other GM cars have the spring-loaded brass "release" pin for the removing the lock cylinder, so if the "release" pin in the switch is missing or stuck down the lock cylinder will not stay in the switch.
        Good luck.
        Pete
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11320
          Re: ignition switch
          Michael,
          You may want to check the area where you were working. It may have fallen out. Some switches had a removable brass button and spring. Some were kept in with a dimple in the housing(pictured repl switch). Did the switch come with a key tumbler? If not then yes the brass button and spring may be a separate item.
          With the button there, it keeps the tumbler from turning past LOCK, unless you insert a paper clip in the tumbler hole, then turn CCW past LOCK with the key inserted. You can see a raised bump in the tumbler back on this one that was in our 63(wrong cuz it's a 2 hole faceplate, s/b 1 hole)
          Rich
