F41 front springs - NCRS Discussion Boards
F41 front springs
  • Lynn S.
    • November 1, 2004
    • 99
    F41 front springs
    Restoring a 69 L89 car with F41 suspension. Unable to find correct hot rolled front springs. Any supplier suggestions? I have the original springs, blasted and in primer. Is there a paint coating that will not cost me points at judging. Any advise greatly appreciated as I do not want to take this thing apart again.
  • Kent K.
    • December 1, 1982
    • 1139
    Re: F41 front springs
    Check the archives under "Posted By: Mark #28455 Date: Sunday, 15 October 2006, at 10:13 p.m." for F41 front springs.
    When it comes to a paint coating, on my '67 restored in 1993, I used Coricone which is a parifin based coating to prevent rust. If applied in light coats to fully cover the part, rust will not occur. The coating may be removed with a laquer dampened rag. I don't have a contact for Coricone and if you find one, please post it.
    Kent
    Kent
    NCM Founder - Member #718
    • Dan Pepper
      Re: F41 front springs on Ebay
      Will these work?
      • Dick W.
        • 10483
        With the yellow tags, they are probably service replacements, but should work very well.
        Dick Whittington
        • Lynn S.
          • November 1, 2004
          • 99
          Thanks for the help.
