66 rear end identification ? - NCRS Discussion Boards
  • Bruce L.
    • December 1, 2000
    • 35
    I just pulled my rear pumpkin from my 66 today. The ID code is AM8 30 65. According to my references AM is 3.36:1 posi (small block), 8 is the month ( AUG.) and 30 would be the day. Is 65 the year? "Corvette by the numbers" by Alen Colven makes no reference to a year marking. They say that it should have a W at the end for Warren, Mich. Also they say that under the AM should be a posi. traction code E for eaton. The way I read it everything seems to make sense. My car has a birth date of Sept. 7 1965. Any of your expert help would be appreciated. Thanks, Bruce
  • Wayne M.
    • March 1, 1980
    • 6414
    Colvin is describing '66 Chevrolets in general
    And your interpretation of the coding is correct for 1966 (and at least through 1967 -- others may say when the Warren and Eaton coding came into use).
    If you pull off the rear cover, there's also part #s, teeth ratios and dates on the ring gear and the end of the pinion gear. Good hunting.
      Re: 66 rear end identification ?
      Bruce -
      There was a LOT of variation in how Warren stamped the diffs, even from day to day; some have the "W", some don't, some have the "E", some don't. Photo below is my '67 original "AM" 3.36 Posi - no "W", no "E" either. Yours sounds fine.
      • Rick S.
        • January 1, 2003
        • 1203
        Here is my 67 3.36 posi made a couple weeks after John's.
        • Bruce L.
          • December 1, 2000
          • 35
          Thanks guys you are the best! NM *NM*
