56 - 57 tail pipes - NCRS Discussion Boards
56 - 57 tail pipes
  • Edward M.
    • November 1, 1985
    • 1922
    56 - 57 tail pipes
    I am wondering what keeps the tail pipes on 56-57 Corvettes from burning the fiberglass. I know the pipes go through a fiberglass tube and exit through the rear bumper. Doesn't that get hot? And what would happen if you ran a car without the rear bumpers, and just let the tail pipes come out through the tubes?
    • May 31, 1974
    • 8396
    Re: 56 - 57 tail pipes
    pipes would have to touch the tubes to damage the resin in the fiberglass.mike
    • Brett H.
      • January 1, 1996
      • 367
      I am doing a frame off on a 56. WHile cleaning the bottom of the car, I noticed a few dark brown/black spots from the exhaust. Not uncommon, I wouldn't think.
      • Roy B.
        • February 1, 1975
        • 7044
        also body heat shields *NM*
        • Brett H.
          • January 1, 1996
          • 367
          Re: also body heat shields
          That 53 looks familiar???
          • Roy B.
            • February 1, 1975
            • 7044
            I save pic's for down the road to show people when I see a correct part or something good.I see a V8 engine on the frame , dont think it's your's.
            By the way when did NCRS say the sides of the under body were painted black.
            • Brett H.
              • January 1, 1996
              • 367
              That's actually 1953 #130. Only 53's had undercoat from the front to the rear, as you see here.
              My picture, ha!
              • Roy B.
                • February 1, 1975
                • 7044
                Sorry Brett I dint realize that only 53 did that ,but I've seen it done on NCRS 54's and some 55's which I know 55 dint! Hope you dont mind me using your pic.
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Brett question
                  By the way any one reproing the headlight seals with the wire coated rubber .
                  • Brett H.
                    • January 1, 1996
                    • 367
                    Re: Brett question
                    My pics are always ok to use, Roy. Haven't seen the seals for sale as a repro.
