thermostats housing - NCRS Discussion Boards
thermostats housing
  • Tony C.
    • February 29, 2008
    • 117
    thermostats housing
    I have a thermostats housing with the casting # on the base GM 3958002 dose any body know what it's for.
    Thanks Tony
    • 43241
    Re: thermostats housing
    Tony------
    Is it manufactured from die cast aluminum with a configuration similar to the vastly more common GM #3877660?
    • Tony C.
      • February 29, 2008
      • 117
      Hi Joe
      It's very much like 3877660 but with out the throttle spring tab.
      Thank Tony
        • 43241
        Tony-----
        That's what I figured. This is one of two thermostat housings that were used in PRODUCTION only for applications not requiring a throttle pull back spring anchor. The other was GM #3972128.
        Can you post or e-mail photos of it?
