67 steering column wiring - NCRS Discussion Boards
  • Jeremy Hedges
    Does anyone know what the different color wires go to on the plug that comes from under the dash? Example: black = horn, etc. The AIM doesn't say in the scematics.
    Jeremy Hedges
    #31711
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 67 steering column wiring
    Jeremy,
    I believe the info you want is on UPC 12 D3, of your AIM.
    14W = brake switch
    20DG = right stop lights
    20Y = Left stop lights
    14PPL = Signal Flasher
    14 BRN = Hazard Flasher
    20 DBL = Right front signal & dash light
    20 LBL = Left front signal & dash light
    20 BLK = Horn Relay
    • Jeremy Hedges
      Thanks Steve *NM* *NM*
