found it - NCRS Discussion Boards
found it
  • Mike M.
    • May 31, 1974
    • 8386
    found it
    been looking for bowden cable housing, .184" in od, to replace the housings on my 57 vette hood release assembly. nobody had the correct OD(which is necessary if you want the housing to remain retained in the barrel of the hood pull). was rummaging thru the shop the other day and came across a Mig welder wire conduit i'd bought years ago for my welder. can't remember if it was ordered for my first mig, a Solar mig or my second mig, a snap-on. anyway, the product to seek is a Tweco Mig-Gun "optimum" wire conduit, part # 44-116-25, stock # 1440-1115. there is enough cable housing to do 3 pair of 56-57 hood release cable assemblies.mike
  • David B.
    • July 31, 2004
    • 330
    Re: found it
    Mike,
    Is this it?
    Distributor of industrial, medical and specialty gases as well as a product line of safety products, welding equipment, specialty tools, and MRO products.
    That would be correct for the w/washer cable as well, wouldn't it? (foot pedal to motor)
    Dave
    Dave, 1969 427, 1957
    Previous: 1968 427, 1973 454
    • Mike M.
      • May 31, 1974
      • 8386
      Re: found it
      the cable i got years ago has a plastic liner on about 3 feet of the 25 foot length of cable whereas the one on your link appears to have plastic insulation its entire length. mike
      • Gary C.
        Administrator
        • October 1, 1982
        • 17673
        Re: found it
        Mike, Tweco 800-426-1888 in Denton, TX still produces the 1/16 inch cable per the stock no. you listed for $31 each. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Edward M.
          • November 1, 1985
          • 1922
          Re: found it
          Mike;
          I am very interested in your hood cable rebuild effort. I will need to do the same thing to my 56. Tell us all about it.
          • Mike M.
            • May 31, 1974
            • 8386
            Re: found it
            will try to do an article for the Restorer.Disassembly of the multiple pieces that constitute the assembly is a PITA but its gotta be done in order to have the handle and hanging bracket chrome plated. mike
