'62 Rear Gearing Help - NCRS Discussion Boards
  • David K.
    • February 1, 1976
    • 592
    I am confused. The rear housing has the tag on that says it has a 3.55 gear. I just wanted to verify it, so I turned the rear wheel one full turn, but the driveshaft only turned about 1 5/8 turn. Something in my mind, doesn't add up here. What am I doing or thinking wrong here?
  • Mike E.
    • February 28, 1975
    • 5138
    Re: '62 Rear Gearing Help
    Probably turned 1 3/4 turns. Times 2 equals 3.50 Probably a 3.55--OR--what resource are you using for your information? I tag with no punches, cuts, or holes, is a 3.36, in spite of what Noland says. 2 X 1 5/8 = 3.25--could be a 3.36
    • David K.
      • February 1, 1976
      • 592
      I happened to have the Paragon catalog handy. The tag they sell for a 3:55 ratio is one round disc with the single hole for mounting. Same as I have on the car.
      • Mike E.
        • February 28, 1975
        • 5138
        Then, if it is the original, it will turn just a hair past 1 3/4 turns to be a 3.55
        • David K.
          • February 1, 1976
          • 592
          Thanks, my confusion says one turn of the rear wheel would mean 3:55 or 3:36 turn of the drive shaft, instead of just half that number.
          • Edward B.
            • January 1, 1988
            • 537
            Try turning the wheel 10 times instead of once to improve the accuracy of your measurement.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17672
              Vendor tags all follow Noland's info
              As Rev. Mike points out Noland's information on tags is incorrect for some unknown reason. And it appears the vendors all used the same information to make their tags from. Maybe Roy can shed some light on how/why this happened. Gary....
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Mike E.
                • February 28, 1975
                • 5138
                Re: Vendor tags all follow Noland's info
                Gary--
                There is GM documentation from earlier (about 59?) that indicates the 3.55 being unpunched. My knowledge base is primarily 61-62 (go figure!)and I've documented 100's of 61-62 Corvettes and passenger cars with the unpunched tag being for a 3.36. Did they change at some point (between the GM documentation and 61-62), or is the documentation in error? I don't know the answer to that one.
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17672
                  Mike, link to GM ECR9904 with tag and ratio info. Ratios in ECR are 12:37 = 3.08, 9:32 = 3.55, 10:37 = 3.70, 9:37 = 4.11 and 9:41=4.55 Always wonderered why they 3.55 tag wasn't shown. Orginally that 3.36 tag was misidentified as 3.55 Gary....
                  NCRS Texas Chapter
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17672
                    Corrected Vendor Rear Axle Ratio Tag Photo
                    Correction to Vendor Catalog Ration Axle Tags. Gary....
                    NCRS Texas Chapter
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17672
                      Re: Corrected Vendor Rear Axle Ratio Tag Photo
                      Not sure why the photo links didn't work - here's the links to them. Gary....
                      http://tinypic.com/view.php?pic=hs6oau&s=3 Vendor Catalog photo - corrected
                      http://tinypic.com/view.php?pic=t6f98h&s=3 GM ECR9904 drawing with correction
                      NCRS Texas Chapter
                      • David K.
                        • February 1, 1976
                        • 592
                        That makes good sense to me. This '62 is a very basic car. The dates on the pig fit perfectly with the car, so unless someone went in and changed the gearing inside, I really expected to see a 3:36 ratio. If they had went into the pig and changed the gears, many people of the time would not have put the tag back on, it would have just fell to the way side. The car is your very basic 250hp car.
