1960 1961 C-1 Hood - NCRS Discussion Boards
1960 1961 C-1 Hood
  • Steven B.
    • January 31, 2007
    • 119
    1960 1961 C-1 Hood
    Can some one please help me correctly identify a 1960 or 1961 C-1 Hood? I know that they all were able to accomodate the top tank radiator, compared to the others. Please help - pics would be helpful too.
    Steve
  • John M.
    • January 1, 1999
    • 1553
    Re: 1960 1961 C-1 Hood
    A 60 and 61 hood are pretty much identical except that the 61-62 style hood has a notch in the center of the front ledge to clear the center clamp on the top of the aluminum radiator. The 60 used a top tank radaiator and did not use this clamp. It was attached on the sides. The difference in the 59 and 60 hoods was pretty subtle, and you can't use the 59 hood on a 60 if it is equiped with a top tank radiator. The front shelf wad widened in 60 to accomodate the wider radiator support that the aluminum radiator used. If you search the archives, I think you will find a pic that was posted by Roy that shows pics of all the hoods side-by-side.
    Regards, John McGraw
    • Erich C.
      • January 31, 2007
      • 137
      Steve,
      In case your having trouble finding that pic in the archives, the pic of the hoods posted by Roy can also be seen at WWW.c1registry.com , click on downloads. the pics in the photograph section.
      • Roy B.
        • February 1, 1975
        • 7044
        I took the family to Disneyland and just got back. Here is the pic. Again.
        • Steven B.
          • January 31, 2007
          • 119
          Roy,
          Thank you so very much!
          Steve
          • Roy B.
            • February 1, 1975
            • 7044
            NCRS should add the pic in thier JM for Reference . To simple??????
            • Terry D.
              • May 31, 1987
              • 2696
              Too logical!!!! *NM*
