1967 vette - NCRS Discussion Boards
1967 vette
  • Joe C.
    • April 30, 2001
    • 126
    1967 vette
    Besides seeing a tank sticker- is there a few quick items to check to see if a "big block" is really suppossed to be in the car. thanks
  • Tom D.
    • September 30, 1981
    • 2134
    C2 Check the curve (90 deg.) at front of fuel line *NM*
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
      Re: 1967 vette
      Joe -
      A few "quickies" (almost all of which can be faked):
      Must be a St. Louis body
      Rear stabilizer bar
      7/8" front stabilizer bar
      Caps & bolts on yokes at inner half-shaft U-joints (not U-bolts & nuts)
      4 holes on rear side of pass. side inner fender for expansion tank bracket rivets filled with bond.
      Hood support on driver's side
      6000 redline for 390 & 400hp, 6500 redline for 435hp
      60 psi oil pressure gauge for 390 & 400hp, 80 psi for 435hp
      T.I. if 435hp
