69 headlamps p/n ? - NCRS Discussion Boards
69 headlamps p/n ?
  • Frank Bernier
    69 headlamps p/n ?
    hi guys
    what would be the correct part number for all 4 headlamps for 69 vette ?
    also i think they are a supose to be dated ... right ?
    when a car is geting judged ... do dates geting judge also or not ?
    -Frank
    • 43221
    Re: 69 headlamps p/n ?
    Frank-----
    The part numbers were GM #5956001 for both inner headlamps and GM #5956002 for both outers. However, these numbers are pretty meaningless since the numbers usually don't appear on the lamps, themselves. Plus, these part numbers were used over a fairly long period of time and the actual configuration of the headlamps changed in certain ways over that period. So, even if you found any NOS lamps with these numbers on the box, they would not necessarily be configured exactly like those used in 1969.
    • Frank Bernier
      ok... is it still possible to find nos headlamps for a 69 ?
      and what details should i look for ? to make sure i get real one ... and not repro !!!
      if your car is geting judge , do the dates mather ?
      Frank
        • 15601
        Frank,
        The ORIGINALLY installed lamps for your 1969 had an orange ink stamp on the back that included a date. Since it is on the back, and not visible when installed, the date is not judged.
        There have been numerous posts on the board about headlamps, including the prints for some of them. As cumbersome as it is, search the archives. Before you start you should know that one of those posts pointed out that lamps generally fail because the vacuum is no longer intact. This happens as the lamp ages, even on the shelf. Short story, even if you find NOS headlamps, plugging them in stands a good chance of destroying their function.
        Remember -- NOS is not always either the right part or a functional part.
        • Frank Bernier
          so if i buy repro headlights ... will i loose points ??... cause judges can identify repro lamps ...right ???
            • 15601
            Right, but only a couple of points *NM*
