How available are tubes for wonderbar? - NCRS Discussion Boards
    • November 1, 1991
    • 146
    My radio finally quit. Junk, only lasted 46 years. Are the tubes still avalable and where should I look?
  • Robert S.
    • July 31, 2004
    • 377
    Re: How available are tubes for wonderbar?
    I got a complete set for my 54 from these guys...
    Antique Electric Supply
    Bob
    • Verle R.
      • March 1, 1989
      • 1163
      Jack,
      Look in the NCRS Driveline. I have seen ads for radio tubes before.
      In addition to the tubes it is likely one or more of the capacitors are bad just from age. To make it work well you should replace all capacitors.
      Unless you are knowledgeable in electronics it would be better to have the radio redone by a professional. I just had a 65 radio refurbished and it works great. There are several competent shops that can do the job.
      Verle
      • Phil P.
        • April 1, 2006
        • 409
        you might get away with an oz4 ocsillartor *NM*
        • Chuck S.
          • June 30, 1991
          • 184
          Re: you might get away with an oz4 ocsillartor
          Other that the OZ-4 tube, often it is the vibrator. Don`t replace it with a "solid state" one without replacing your capacitors.
            • November 1, 1991
            • 146
            Sounding more and more like this is a job for an expert rather than just replacing tubes. Not real comfortable sending the unit off to just anyone.
            • Dino L.
              • February 1, 1996
              • 694
              I would recomend replacing the tubes...so easy, Before sending it out....try ebay and search on the tube numbers printed on your originals. buy yourself some NOS vintage tubes can readily be purchased on ebay. a complete set should run around $50
              Dino Lanno
              • William S.
                • August 31, 1999
                • 39
                Jack,
                Pardon my late post to your response. These radios are not difficult to repair, and you can probably do it yourself with a minimal number of tools. If you want to pursue repairing it on your own and when you get the radio removed, send me an email (go to User Profile) and I will be happy to work with you in attempting to get your car's radio fixed.
                Bill
                • Scott S.
                  • March 1, 1979
                  • 747
                  Bill, Check you Driveline ads. A.R. Eddy Hammer-Huber past national Judging Chairman has tubes for sale Clevland, OH area.
                  Best of Luck.
                  Scott
                  #2379
                    • November 1, 1991
                    • 146
                    Thanks. Have some tubes to be shipped Monday by a board member. Hope that does it. I'll get in touch if it doesn't.
