Eastwood's zinc plating kit... - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I've been using the Eastwood zinc plating kit with good results. Normally, the bolts come out just the way I want, not too shiny. Recently, they are coming out too dark. In the past, if this happened, I simply cleaned up the zinc bars and the shine on the plating returned. The bars are fairly new. I realize they could be buffed to increase their shine, but I've never had to do that before and was happy with the results. Anyone experience this?
    Re: Eastwood's zinc plating kit...
    'Black' finish out of the tank can be the result of several things:
    (1) Voltage/current is incorrect and you're laying down plating WAY too fast.
    (2) Your electrolyte is 'over the hill' and it's time to discard/replace it.
    (3) Poor plating practices including: improper pre-plating metal preparation, not cleaning 'salt' build-up off your plating annode, failure to filter particulate matter out of your electrolyte between plating sessions, failure to monitor/maintain correct/original electrolyte Ph levels, and improper electrolyte working temperature.
    Eastwood provides a very easy way to get into the home plating process (kit entry cost is low), but they offer little/no support regarding what to do if/when things go bump in the night.
    Caswell, on the other hand, sells a VERY nice book that gives you technical background & trouble shooting tips plus they maintain a user support forum for information interchange as well as email Q&A support...
    • Gerard F.
      • June 30, 2004
      • 3806
      Rob,
      Here's what I do with a Caswell plating kit:
      Prior to plating, I dip the anode in muriatic acid (cut 2 to 1), neutralize it and dry it off. Then I wire wheel the anode to a shine.
      With the Caswell kit, if you want to it to come out shiny you add a brightener and prep the part to a shiny finish. I'm sure Eastwood has a similar brightener in its mix which wears out over time.
      I never use brightener with my Caswell kit as it always wears out and with little use, I think it is a waste of money. My parts always plate to a dull gray. If I want a shiny finish, I just buff the dull gray to a bright zinc finish.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
