C1 '57 generator questions - NCRS Discussion Boards
  • Rod K.
    • 443
    I have what appears to be a 1102043 generator (w/o tach drive) for my '57, but it has no tag (rebuilt years ago, probably a PS gen, but it looks right). Can someone help ID this, please? It seems to conform to the JG description, end plates, etc, but I'm not sure about the position of the pivot holes or bushing size. JG states "All 1956 and 1957 engines used generator end frames that mount close to the exhaust manifolds", but doesn't give a dimension. Without being able, at this time, to verify by checking the fit between the body and the manifold per the JG, can someone provide a dimension from the case to the centerline of the front mounting hole and the OD of the rubber bushings?
    Also have a 1102097 8B2 generator which doesn't appear to be a Corvette number. Can anyone provide an identity, please?
    One more. How long was the 3728514 mounting bracket used? Was it just '56-'57, or was it used in later years? Trying to determine how rare (hard to find) it might be.
    Thanks in advance for any help. Much appreciated as always.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 '57 generator questions
    Your generator front aluminum plate will have no fins on the back side that car has ,Corvette is (smooth) .When it's on the engine from the passenger side looking at the red tag it faces you , car faces toward the driver fender! And a corvette having the right front and back plate you cant put your finger between the Gen, housing the rubber mounting area, the car gen yes because it sits higher then Corvette . so a car you can ! Just some simple little things when looking at one , Sorry I don't have a better pic. Of the front plate back side.
    • Rod K.
      • 443
      Thanks, Roy. That looks like the one I have. I take it this is a photo only and you don't have one available to confirm the distance from front mounting hole centerline to the case?
      From catalog listings it appears the 3728514 "U" mounting bracket was '56-'57 only. Do you know if it was changed for '58 and later?
      • Roy B.
        • February 1, 1975
        • 7044
        this is a photo and I dont know the distance, 56 to 58 should be the same , later ?? sorry I cant help more!
        • Rod K.
          • 443
          Thanks, the photo helps a lot. I think mine's OK.
