thread sealant for a 69 - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    What would be the proper thread sealant to use on the various pipe thread fittings like on the water pump, intake manifold and oil pressure port?
    I assume that teflon tape is wrong so that's out. Would that thick dark permatex sealant be right or is there a white thread sealant that would be better?
    Just trying to make it the way it was.
    Greg Linton
    #45455
  • Dick W.
    • 10483
    Re: thread sealant for a 69
    Personally I use Loctite PST. It is a teflon paste. Just a dab on the first thread or two. Wipe off any excess so that it does not show.
    Dick Whittington
    • Tom D.
      • September 30, 1981
      • 2135
      C1 C2 283 327 How about for head bolts? *NM*
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
        Re: C1 C2 283 327 How about for head bolts?
        Tom -
        Permatex #2 or ARP Thread Sealer.
        • Greg L.
          • March 1, 2006
          • 2291
          Thanks Dick.
          So I guess any quality thread sealant would be okay then as long as it doesn't show. For some reason I thought that it wasn't uncommon to see trace amounts of a dark or white colored sealant where the fitting enters the hole but maybe I'm wrong.
          If these trace amounts were typical then that would be the look I would be going for but if the fittings had a nice clean appearance then that's even better.
            Greg -
            No sealants were used in production on pipe thread fittings ("Dryseal" threads in GM parlance); that's why you don't want any to show.
            • Greg L.
              • March 1, 2006
              • 2291
              Oh I didn't realize that. Thanks John.
              I guess that would explain why the steel fittings were such a bear to get out of the alumunum intake!
              • Donald M.
                • December 1, 1984
                • 498
                Greg, you do not want to use any thread sealer on the coolant sending unit. It will insulate the body of the sending unit and give a false reading or none at all. A clean surface is necessary for proper grounding of the sender to the manifold.
                Don
                • Greg L.
                  • March 1, 2006
                  • 2291
                  Thanks a good point Don and thanks....I never even thought of that.
                  • Norris W.
                    • December 1, 1982
                    • 684
                    Not correct but not very noticeable:
                    My '68 427 Biscayne has an aftermarket alum. waterpump that I couldn't make stop leaking around the bipass hose fitting in spite of trying most eveything that's worked for me before. I was whinin' about it at O'Rilley's and a guy standing there showed me some silver silicon type stuff that's branded water pump and thermostat sealer. It's the best damn stuff I've ever used and works MUCH BETTER than the RTV Silicon or plumbers sealer with teflon added that I've also used.
                    Since it's silver in color it doesn't show nearly as much as a contrasting color.
                    • Paul J.
                      • June 30, 1999
                      • 83
                      My new head bolts (felpro) came with teflon on them I think, anyway it is white.I just bought some Permatex pipe sealant with teflon to put on the bolts because I had to remove the heads and some of the coating was gone. Heads had not been torqued yet. Has anybody used this or would Permatex #2 be better?
                        • 43229
                        Paul-----
                        Permatex (Loctite) pipe sealant with Teflon will work well. I use it all the time. It's even sold under a GM part number, but it's the same as you can buy in an auto parts store.
                        • Paul J.
                          • June 30, 1999
                          • 83
                          Thanks Joe. I also have some Oatey pipe joint compound that I used on some air compressor fittings that worked much better than tape and is rated for liquids to 10,000psi from -50* to 500*F. Do you think the Oatey is the same as the Loctite? Is all teflon pipe dope the same? The loctite has not been opened and is still returnable.
                            • 43229
                            Paul-----
                            I doubt that the Oatey is the same as Locktite, although I think it will work ok.
