65 rear end codes - NCRS Discussion Boards
65 rear end codes
  • Donald S.
    • January 23, 2008
    • 183
    65 rear end codes
    this 65 has AU stamped on the bottom with the date but when i took the body off it also has AU stamped on th top of the pumpkin with nothing else i have never heard of this before all mt book says is on the bottom with the date code...
  • Wayne M.
    • March 1, 1980
    • 6414
    Top Differential Stamping --- late 396
    at the top rear edge of the carrier. Judging manuals don't refer 'cause impossible to see.
    Here's the bottom flange stampingm (3.70 ratio):
    • Donald S.
      • January 23, 2008
      • 183
      Re: --- late 396
      i figured that was true ie not visible so not mentioned thanks for the conformation....
      • Barbara S.
        • April 30, 1981
        • 599
        Re: Top Differential Stamping --- late 396
        Wayne. I wish I had an FA. I have an FB.
        Tony
        • Keith B.
          • December 1, 1991
          • 397
          Re: Try an FC (4:56) for real Fun *NM*
          Keith Burmeister
          • Barbara S.
            • April 30, 1981
            • 599
            What's that like, Keith?
            • Keith B.
              • December 1, 1991
              • 397
              There really is no 1st gear to speak of but second and third really brings the RPMs up. I haven't had the guts to keep power on through 4th. Even in normal traffic you feel like you need to shift. Tony if your at the Nationals you can see for yourself!!!
              Keith
              Keith Burmeister
