I am in the process of removing the driver's side trailing arm, half shaft and strut rod from my '67 small block for a rebuild. I did the passenger side last year and had very few problems.
I need help removing the strut rod from the differential end. The strut rod is bent so I plan on replacing it. I can rotate the camber adjustment bolt but I just can't remove it. The bushing may be seized onto the bolt.
Any ideas would be greatly appreciated.
