Washer pump dissasembly - NCRS Discussion Boards
  • Donald G.
    • October 17, 2006
    • 16
    Does anyone know how to remove the plunger head from the stem? It will turn and it seems as though there must be a way to remove it but I can't get it off.
    Thanks.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Washer pump dissasembly
    Don
    Push in and turn 90 degrees will remove the plunger on some years.
    Lyle
    Lyle
    • Gerard F.
      • June 30, 2004
      • 3806
      If it is like a 67, push with your thumb and a quarter turn. See this post in the archives:
      The other problem is usually the little rubber check valves in the plastic pump housing not seating.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Donald G.
        • October 17, 2006
        • 16
        My 69 pump does not have a bellows. It has a plastic piston with a seal like a square O ring. I thought it would come off as you describe but no cigar.
        Don
          The pump's piston assy IS removable... Dis-mount the washer from the wiper motor, flip it upside down and study the mechanics of the piston's driving rod. You'll see you have to disassemble the washer's relay, carousel and drive gears to gain sufficient freedom. Then, it's simply a matter of tapping the pump cylinder/piston out of the 'slot' in the washer plate that holds them in place.
          Get replacement parts from any equivalent GM washer pump out of a scrap yard. Where you'll be in a world of 'hurt' for replacement parts is on the opposite side of the pump...those components that service the head light washer sub-system!
          • Kenneth B.
            • August 31, 1984
            • 2091
            Dose anyone know where to buy the spring that works the lever to the plastic gear for my 70 LT-1? THANKS
            KEN BARRY 7808
            • Donald G.
              • October 17, 2006
              • 16
              I have the plastic pump removed from the mounting plate but the piston just will not come off the actuating rod. I bought a replacement from Delco but it is black and I rather not use it.
