53-54 over heating problem - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    I've had a couple of new owner asking me why their engine gets hot climbing hills or in traffic stating the engine was rebuilt. One guy changed out the water pump, radiator,even had the head removed again looking for cracks.
    I wrote many years ago that when you have the engine rebuilt be sure they know it's a Corvette not a car engine telling them NOT to install the large freeze plug at the engine front area because Corvette water pump was lowered to clear the upper Radiator hose . Car did have the large plug but NOT corvette, some shops will add it thinking thier doing a Car engine. (see spacer plate) . If any one reading this has this problem over heating , just remove the pump only and look in to the spacer to see that it's not installed .
  • Roy B.
    • February 1, 1975
    • 7044
    PG oil level
    I also get questions about the cast iron PG leaking when setting for some time . I tell people that the Convertor will allow 1/2 or little more quart of trans oil to drain back into the main case . It will leak at the shifter shaft seal or filler tube o-ring ( usually at the filler o-ring) gets hard. If they just leave the oil 1/2 quart low or a little more it will stop and not hurt the trans. I do and never hurt anything for 30 years. You can tell when it needs filling if the trans slips on hard left turns.If it does it still dint hurt the trans. Some times they have the wrong oil stick.
