70 corvette jack - NCRS Discussion Boards
70 corvette jack
  • Mike G.
    • July 31, 2002
    • 709
    70 corvette jack
    is a 69 jack the same as a 70? i see some jacks with an A stamped on the top. what do i look for in a correct 70 jack? what years are correct?
    • 15601
    Re: 70 corvette jack
    There is a date code on the jack, so that limits what you can have if you intend to have your car judged.
      • 43221
      m and Terry------
      Yes. However, other than the date code, the 1969 and 1970 jacks are the same. Also, a jack from a late 1969 might have a date code that would be acceptable for an early 1970.
      • Mike G.
        • July 31, 2002
        • 709
        i can work the date code thing out as long as the jack is the same. the 74 is a 3X and the 69 is a 9D. my car is a june 70 so the 69 is probably too early. but if that 9 were a 0 ...
          • 15601
          Sometime after 1972 the size of the date stamp increases.
          • Mike G.
            • July 31, 2002
            • 709
            thats good to know. i need a 72 back
