67 BB Engine Removal - NCRS Discussion Boards
  • Steve M.
    • October 22, 2006
    • 88
    I'm going to take the 427 out of my 67 coupe. Several postings in the archives on engine removal contained helpful tips. My question is: Do I need to remove the radiator support if I plan to leave the transmission attached to the block as a unit? Thanks in advance for the help.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 67 BB Engine Removal
    It will clear the support.
    • Steve M.
      • October 22, 2006
      • 88
      One less thing to do!
      • Wayne W.
        • April 30, 1982
        • 3605
        Re: Thanks
        You will have to tilt the engine back a bit.
        • William L.
          • December 1, 1988
          • 944
          Re: Thanks
          Make sure your engine hoist is capable of lifting the engine high enough to clear the core support?
          Bill Lacy
          1998 Indy Pacecar
          • Steve M.
            • October 22, 2006
            • 88
            Re: Thanks
            I'm in good shape there. Thanks
              Re: Thanks
              Remove the distributor, and use a tilter on your hoist.
              • Myron Sleeva
                Much less stress if you remove the rad cradle. *NM*
                • Steve M.
                  • October 22, 2006
                  • 88
                  One more question
                  First, Thanks again for the tips. Do I need to disconnect the drive shaft from the rear end and remove it or will the tranny slide forward enough to get free when I pull the engine. Thanks
                  • Stephen L.
                    • May 31, 1984
                    • 3158
                    Re: One more question
                    Pull the drive shaft and plug the trans output shaft to avoid oil leaking from transmission when tilted
                    • Steve M.
                      • October 22, 2006
                      • 88
                      Thanks *NM*
