1967 Job Number - NCRS Discussion Boards
1967 Job Number
  • Jim D.
    • December 1, 1994
    • 82
    1967 Job Number
    I am cleaning a survivor 1967 and I find the job number as L296. I have never seen a job number with a letter as well as the numbers. This appears very clear both on the firewall passenger footwell and the rear bulkhead. It is in yellow marker. Is the use of a letter very common.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1967 Job Number
    AO Smith body. It will also have a number on the Z bar behind the dash.
    • Warren S.
      • April 30, 1987
      • 100
      Re: 1967 Job Number
      My St. Louis built 67 has 408F in white marker on the firewall side of the passenger side footwell and the rear bulkhead.
      • Donald T.
        • September 30, 2002
        • 1319
        Re: 1967 Job Number
        Jim,
        A.O. Smith body cars have a letter designation followed by a three digit sequential running 1-500. So the job numbers ran A1-500, B1-500, C1-500, etc. You may want to check the archives as there is quite a bit of info posted on AOS job numbers. Hope that helps.
        • Barbara S.
          • April 30, 1981
          • 599
          From my June, '67 A. O. Smith body
          This is located on the rear bulk head just ahead of the gas tank. The same L383 was also written in yellow grease pencil on the engine side of the lower passenger floor board. "383" was also written in red grease pencil on the steel horizontal dash support (driver's side).
          Hope this helps.
          Tony
          • Kevin M.
            • November 1, 2000
            • 1271
            Re: From my June, '67 A. O. Smith body
            Surprised it was cursive, with the death of cursive because of computers, some day I'm sure the mark will have to be described as a old fashion hand written L.
            Kevin
            • Jack W.
              • August 31, 2000
              • 358
              My AOS Z Bar number
              As Wayne said, on the cross-brace behind the dash cluster (on my 65 AOS body car):
