c2 speedometer face - NCRS Discussion Boards
c2 speedometer face
+ More Options
Posts
  • John D.
    • January 1, 2004
    • 29
    c2 speedometer face
    Any recommendations as to who makes the nicest quality speedometer face for a '67?
  • Tony C.
    • February 29, 2008
    • 117
    Re: c2 speedometer face
    Hi
    Call D&M Classic Instrument Restoration Shop 46 Grand Ave. Greenville, SC 29607 1.800.722.0854
    Tony
      John -
      If you only replace the speedo face, you won't like looking at the old tach face; then if you replace the tach face too, you won't like looking at the other four old gauge faces; then......
      • Ken A.
        • July 31, 1986
        • 929
        Did you want a new dial plate or a "rescreen"?
        • John D.
          • January 1, 2004
          • 29
          Ken--I'm not sure what I want. I haven't yet pulled the cluster from the dash so I'm not quite sure what I'm dealing with. The car had gone through a restoration in 1985. In the right light I can see a slight difference between the speedo and tach face plates. The speedo has a bit more glossy background and somewhat of a ripply effect so I'm not sure if it's a repo plate or rescreen. If it wasn't for the fact the speedometer quit working I probably wouldn't mess with it. Nonetheless, since I've got to pull it out I'd like to improve it, but wasn't planning on redoing all the face plates as the others look fine.
