Steering knuckle gasket.... - NCRS Discussion Boards
  • Bill Dangora
    Should the steering knuckle gasket (slips over the front spindle on the steering knuckle, the disc brake splash shield then bolts to the steering knuckle, followed by the hub/rotor assembly) be replaced periodically?
    Does anyone have a part number for it?
    Is there a preferred replacement?
    Thanks in advance for any and all comments.
    Bill
    • 43240
    Re: Steering knuckle gasket....
    Bill------
    The gasket only needs to be replaced when you have the front knuckle and splash shield disassembled for other reasons. It does not need to be periodically replaced otherwise. It's still available from GM under GM #3953431 for $3.66/each.
    • Bill Dangora
      Thank you for the information, Joe.
