C1 519 block plug above oil filter - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    What type of plug was orignally installed for the oil passage above the oil filter on a 519 block? Should it have a square head plug like the front oil passage above the water pump only larger? I have a 739 block and it looks like a small expansion plug verses the 519 has a recessed hex installed. The expansion plug appears to be smaller than the 519 recessed hex plug. Thanks, Ted
