C2 front license plate bracket angle - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Should the license plate be verticle when attached? Mine is on a slight forward angle. I don't want to bend it back if it is correct as is.
  • Alan Drake
    Re: C2 front license plate bracket angle
    Yes it has an angle. Check your AIM for correct placement on center bar assembly.
    • Tom B.
      • March 1, 1978
      • 720
      If I remember right the bottom should be out further than the top.
      • Larry M.
        • January 1, 1992
        • 2694
        Rob:
        On my 1967 small-block car, the front license plate has about a 7-8 degree forward angle: i.e. the license plate points slightly down towards the ground from vertical. Same as yours.
        It also appears this way in the 1967 AIM.
        Larry
        • Wayne M.
          • March 1, 1980
          • 6414
          65 Road Test pics show it best
          Went through all my magazine road tests 1963 thru 1967. I figure the pic below from an August 1965 Road & Track test shows it best. At least 75% of the other years shots showed the same. Note California manufacturers' plate.
          Tilt not mentioned in '65 TIM&JG.
          I'll leave it to you guys to calculate the correct angle.
          • Richard S.
            • November 1, 1994
            • 809
            Re: 65 Road Test pics show it best
            Go ahead and bend it........
            • Alan Drake
              Rob,
              do a search on 28 June 2006 looking for "C2 Front License Plate Bracket" you will find the real story. (forget my 80 degree listing - it was measured backwards, SB 10 degrees)
